cattle rancher
- 0
- 6
- Boise City, Oklahoma
Hey, new guy here. I own 2 M35's, a '68 Kaiser, and a '77AMG.
My hired man went to start the Kaiser one day, turned the accesory switch on, hit the start button and it clicked and nothing happened. He roll started it for a couple of days and then one day it started with the button. But, now won't start again. Of course the gauges don't work in the cab. As best as I can tell I'm getting 24 volts out of the batteries and I checked and cleaned the cables. There are 4 wires connected to the acc switch and I'm getting electricity to 2 of them but with my limited understanding of a volt meter I think I'm only getting 12 volts from each wire. At least it doesn't read as high as when I tested the batteries. I tested the switch and it works.With the switch disconnected, I pulled the rubber protectors back to expose the wire connections to all 4 wires. When I touched the ( switch-on ) wires to the hot wires the voltmeter goes to 0.
I've read about the circuit breaker and where it's located but what does the silly thing look like? Does the wiring go to the cb first and then the switch or does it go to the switch and then the cb?
I sincerely appreciate any help!!
