M35A2 in-tank fuel pump gasket
Mrmag1
Head of Stuff N' Things
14
Hereford Arizona
Well I've decided to drop the tank and pull the fuel pump because she stopped pumping (fuse and leads are good and power is flowing). So I'm going to clean the tank and replace gaskets on the pump and sender...
There is the problem, I can't find for the life of me a gasket for it, so I'll make my own.
What have you used to make yours or do you have a line on a proper one?
1,187
I've made them with thin cork sheet, and other gasket sheet materials.
I've also reused the old(even if cracked).
Either way I seal both sides with a thin coat of Indian Head Shellac.
Mrmag1
14
Hereford Arizona
Thank you doghead, the more I think about it the gasket part of this may be the least of my problems.... Yeah cleaning out a fuel tank.
1,187
It's not that bad to do.
I pull the plug and flush them with a gardenhose, with the tank on a plastic 50 gal garbage can.
Reach in with your hand and swab around with a rag. Maybe push it around on a short stick too, to get under the slosh panels.
Mrmag1
14
Hereford Arizona
I've read alot of things on here and some that where either expensive or downright crazy when it comes to cleaning one out. hopefully I can get it done with diesel and a rag.
