M35A2 leaking front seals
rfischba1
Fort Meade MD
New owner of a M35A2, the right front wheel is leaking what smells like gear oil from the axle boot, the boot looks worn. What parts should I replace? inner outer seals, boots, is there a wheel kit that includes all parts need? Shouls I replace both front wheel sets?
Also one rear wheel seal is leakink, what should be replaced?
Thanks,
cranetruck
75
Meadows of Dan, Virginia
Welcome to the forum!
In the front: Inner seals (both sides and the boot(s) if torn).
Rear: outer seal with cork insert.
These repairs are documented in previous posts, do a search and you should get plenty of hits.
