M35a2 Lockout hub torque
1,814
This is really going to require a call to the hub dealer. Since the hubs weren't factory equipment, the TM won't cover them. Different style of lockouts use different hardware which probably have different torque values. With all that said, I usually hit them with the impact and call it a day but that is with Selectos and the Dualmatics.
DieselBob
13
Arnold Maryland
From TM 9-2320-361-20, "Aline holes in axle flange (3), gasket (4), and hub (5), and install with eight new lockwashers (2) and screws (1). Tighten 60-80 lb-ft (81-108 NŽm)."
1,814
Highway 95, If you knew that coming into this, why not look at the TM? What took you hours to find out and posting in 2 different forums could have been found in 2 minutes with the TM.
