Jake0147
- 18
- 18
- Panton, VT
The problem with the OP's brakes can be narrowed down pretty easily. All six brakes didn't fail at once and then recover just as quickly. The trouble is a bound linkage (unlikely but possible) or something related to the airpack. Most likely internal, but not "guaranteeable" until somebody dissects it to see what is on the inside.
AZDeuce, question: When the brake pedal gets hard, if you pinch the seat good and tight and rail down on the pedal with everything you've got, it doesn't move far but does it give you ZERO brakes, or does it give you "just a little bit but completely inadequate" brakes? That might help you narrow down without a doubt if it's a mechanical issue or if it's an airpack (power assist) issue.
All the discussion of brake fluid on this site amazes me. DON'T TRUST YOUR BRAKES TO WHAT SOME GUY ON THE INTERNET SAID!!!
You can mix DOT 3, DOT 4, and DOT 5 at will in a deuce. You can find several of the Army's technical manuals instruct that you mix glycol and silicone fluids. There is no reaction, they don't mix, they just sit there and continue to work fine. Seal compatibility is not an issue in this case. The only case where it could be an issue is going the other way, from a DOT 5 only system and adding glycol. Deuces don't have that. They have hand stenciled warnings sometimes, but that's the required practice. The parts the system is made of both before and after the military switched are designed for glycol, the DOT 5 is a retrofit.
When somebody has a picture of snot in their master cylinder and says that it proves there was a reaction... Put it in an analysis kit and send it to a lab, just like taking an oil sample. You will find that the mixed fluids include more than just those two components.
Anyone who has synthetic brake fluid in their vehicles... Make sure all your seals and gaskets are compatible with that stuff... LOL. All I can say is I hope it was the same price as the regular. It's a recent marketing ploy started by one company, followed by another brand supplied by that company... Just a gimick and no more. ALL current main stream brake fluids (DOT 3, DOT 4, DOT 5 and DOT 5,1 ) are, always have been, always will be, and by definition can not be anything but "synthetic" in nature, regardless if it says so on the label or not.
Anyone who takes me at my word for any of this deserves what they get... LOL. Really, this is my contribution to you, this paragraph right here. All of this information IS AVAILABLE TO YOU. Nobody is going to hand deliver it to you, because it is not profitable information. Some guy on the internet says two fluids are can not be mixed. Some other guy on the internet says they can be mixed. One says seals are compatible, one says they're not. What do you do? Pick your favorite and hope for the best? Heck no, It's your brakes for goodness sake. Grab a pickle jar and mix up a witches brew with your fluids, see what happens. Bam! First hand knowledge. Look up replacement seal kits for Deuce wheel cylinders, or complete replacement wheel cylinders for that matter. What does the manufacturer say about compatibility? Or if you're really ambitious, just find the material and investigate it's compatibility yourself.
