- 537
- 42
- 28
- Custer, South Dakota/Black Hills
Often I see questions about finding a 7 rib belt for your A3. Here is a good cross ref chart. If you cannot find the exact size at your location see if you can use one close to the size you want. In an emergency it might just work. Like the 7PK1640 is so darn close to the issue belt it will work well. After all length less that 1 millimeter difference is not a problem.
I picked up a couple of Bando 7PK1640 belts off of Amazon for less than $17 each.
http://crossbelts.com/serpentine/7ribkseries.html
