M35A3 Not Shifting into High Gear!!!!
AceHigh
31
Lake City FL
Did you check the fluid level under the floor on the passenger side? Did it shift OK when you got it and now does not? Have you changed out the filter and fluid? Often it is a badly adjusted shift cable in the shift tower. (Speaking as a person without much knowledge on this)
AceHigh
31
Lake City FL
Good! Mine blew the alternator at the time of pick up so I just put in a commercial 24 volt one, good results so far and less $$$
