- 521
- 55
- 28
- Behind Enemy Lines, Massachusetts
power top too, right?
I will make sure that I get a new o-ring but what kind of lube do you recommend on the bead and o-ring? I read somewhere to use sil-glyde paste from Napa.Make sure you replace the o-rings between the wheel halves. we had to clean rust from the bead area and o-ring groove. bought some beadsealer from oreilly auto parts and painted the bead and oring groove. no more leaks!
Tire lube and a good boot stomp getting it in, tire lube and grab on and pull to get them out.What do you guys recommend is the best way to get the beadlock out of the tire? Does it work best to just try and pry it out? I know that to put it back in requires a ratchet strap but I don't know how remove it properly.
