M35A3 Speedo oil leakage issue
Steel Soldiers is supported by:
Chris DeCelles
Reno ,NV
Read a lot of posts in the past that saved me much troubleshooting time but never asked any questions directly. I am sure someone has seen this issue before, I have a M35a3 that I recently purchased and the speedo has oil puddling in the the bottom of the window. I am fairly certain there is oil coming up the cable on longer drives but can't seem to find an image in the parts manual that shows a seal or p/n for one at the transmission end of the cable. Any assistance on this would be greatly appreciated.
Heavy D.
Newport News, VA
I have this issue as well, is the speedo cable supposed to have oil in it for lubrication and a seal on the speedo failed? Either way my speedo stopped working all together recently so I will likely be replacing both.
Menaces Nemesis
"Little Black Truck" Conservator
66
Denver, Colorado
If your T-case is the same as an M35A2 (forgive me, I know the A3 has the Allison Auto, but I'm not certain what t-case they have)...
Discussion; https://www.steelsoldiers.com/threads/speedo-cable-leaking.29471/#post-354570
New Seals; https://www.ebay.com/itm/2-Pack-Genuine-Kawasaki-92049-7019-Oil-Seal-For-FH-FR-FS-FX-Series-8X14X5-OEM/221993976948?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
When I did mine; https://steelsoldiers.com/threads/w...r-deuce-this-week.67703/page-413#post-2171779
Given that your speedo has been pumped full of oil, you might also want to make sure the lube level in your t-case isn't too high, as well as making sure the vent on your t-case isn't plugged.
Heavy D.
Newport News, VA
Thank you, I will check on all you have suggested.
