M35a3 wheels on a M35a2
ToddJK
4,464
Sparta, MI
Is it necessary to flip the hubs? Is there a clearance issue if they are not or does it just look stupid?
You flip the hubs only if you want to single the rear tires. This is due to the lug nut studs, they are long enough for two tires, flip the hubs and it shortens the lug stud so you can add just one tire and properly tighten it down.
williamh
577
SanDiego Ca.
Not quite. Flipping the hub moves the wheel out a few inches so it doesn’t look funny with the inside rim only. The studs are the same length , the “nut” that goes on the inside wheel has threads on it for another nut to hold on the outside wheel.
Bulletpaluza
65
Georgia
So I don't technically have to flip my hubs?
