pwoodson
- 0
- 0
- Coronado CA
I recently purchased a 1953 M38A1. The speedometer did not work so I removed the old cable assembly and cable. The cable was broken at the connection to the bit which inserts into the transfer case speedo gear. I ordered a new Waterproof Military 60" assembly. When I attached it the cable failed after about 1 block of driving in about the same spot as the old one. It worked for that 1 block (up to 10MPH). Do I need to worry about something wrong in the speedo gear drive?
THis is my first post and first MV or Jeep. Please forgive any mistakes in vocab or etiquette!!
Thanks.
Thanks.
