m54 hydralic head problem
mill1970
worcestershire uk england
hello i seem to be having a problem with my hydralic head when the head is bolted down on to the pump with the side plate off the plate that holds the stop pull cable when i turn the elactric fuel pump on in the diesal tank fuel starts flooding out of the bottom of the htdralic head where the drive cog is see picture can any one help ps when i replace the head should it just sit nicely when doing up the bolts or should the head have a slight spring to it and the bolts push it down into place please help
cranetruck
92
Meadows of Dan, Virginia
Mike I'll check one of my spare pumps and get back with you. Another was shipped this morning and should be in your hands next week. There should be very little spring to it when you replace the head, the cam should be in its low position unless the timing is off...I say again, unless the timing is off...
What I mean is that the cam is out of sync with the gear on the head, which would be entirely possible with the broken quill shaft.
Mike (Mangus580), it's for an m35 based on past info....
