M816 front axle engaged
64
24
Lynn Lake Manitoba
since my 1976 AM General M816 was abused during Hollywood filming the lines were cut to the transfer case where the front drive shaft bolts on. before I bolted the front driveshaft back on I used the air hose from the shop to see if air engages the front drive shaft which is did sort of because the air was not hooked directly( I was just using the blow nozzle in the hole). I hook up an air line to a valve on the trucks air tank and went for a drive. of course I got stuck in the snow and the front wheels did not even attempt to spin. but I did back out from being stuck with no problems. does the top air line which I think is a breather have to be hooked up too???
thansk
Floridianson
2,521
Interlachen Fl.
The transfer case air cylinder has two air lines going to it. Where you have the new Synflex air line hooked up to it now and adding air it would be reverse sprag. The top line or other line is forward sprag. You need to get the poppet valve working as you should not be in forward sprag going in reverse or reverse with forward sprag in gaged. When the poppets are working correct and switching directions the air is allowed to escape from one side or the other air cylinder by way of the vent between the two poppet vlaves.
24
Lynn Lake Manitoba
thank you, it is starting to make sense now. I wish the truck was not stripped during Hollywood Filming.
thansk
