M818 Air Problem
whitsonbrittani
Kentucky
I have an m818 that builds air pressure good, I can hear the governor kick the air compressor off but in a few short minuets it kicks it back on for about 15 seconds. It then kicks it back off and then on again repeatedly in about 15 second intervals. What could be causing this? I know that there is one small air leak but I don't think that could be causing it, could It? Or could water in the tanks possibly be causing this?
Sent from my SM-N950U using Tapatalk
whitsonbrittani
Kentucky
Thank you so much for you reply and the info! You wouldn't happen to know what oil is best to use in the transfer case, transmission and rear end is would you? I can't seem to find a recommendation anywhere.
