M881 help
dmetalmiki
2,034
London England
Freind has an M881 which has failed the uk MOT (3 times!!) seems the wheels have too much free play in the bearings. over 1/4" top bottom ((wheel tyre)) hand check.
The bearings were replaced. SAME problem!! looking at the tm shows NO adjustment possible just torqued up to 100 f.p. and the exploded views dont seem to explain (show) how IN HECK does the adjustment or setup eliminate the (any) free play or conversly prevent overtightning of the bearings. ANY help / knowledge pre experience with this problem (OR FIX) greatly appreciated.
CCATLETT1984
Saint Clair Shores, MI
If the bearings are torqued to spec and you have too much free play, I'd take a look at the spindle to be sure that there are no burs that the bearing surface may catch on, do the same to the inside of the hub.
That inner nut for the bearings should be at nowhere near 100ft/lbs. you wil kill a bearing quick and bend the races with it that tight.
1,824
881 has the unit bearings on the front. Are we talking front or rear? If front, you need to start checking the balljoints in the D44.
dmetalmiki
2,034
London England
bearings m881
ITEM in question FRONT wheel bearings.there is NO play in the ball joints.((ALL other items on this truck passed the mot)) FAIL = this problem with the front bearing "tightness"/un allowable free play.<<PRE>>He told me the manual sez tighten to 100 fp! he (also) states that there is a spacer BETWEEN the bearings to correctly space/set bearing play.(adjustment requirment) <loading> I checked the pages on s.s. docs. and think the preload setting is when the INNER bearing housing STOPS against a 1/16" lip on the spindle. (do I interpret that correctly? if so could the overtitghtning have ""squished"" that shoulder (it's only 62 thou!) so that the inner goes in too FAR allowing unaceptable/unajstable free play in the bearings/wheel??..the mystry deepens...
