M915A1 Dump transformation
panzerwillie
Ok Boys an Girls was hopping to bigging doing this feeling good but iam just getting out of INFLUENZA -A that pick it up from work free of charge off course but it beggings.
I pivk up a Meritor 20k front axle with bendix air disc brakes so took it apart to put new seals and bearings.
G744
Hi PanzerWillie,
I have a complete hydraulic dump system in the classifieds, if you need that.
Best, Dennis
kubotaman
Keeping the 40k lbs rear axles? Good call on switching the front axle, does that model require dual steering boxes?
panzerwillie
Running single steering box and keeping the 40k but will look for a steering box with outlet to make drop axle steer with a ram, good day today boys and girl more to follow
US6x4
Roto-broaches work really well on hardened steel frame rails !
panzerwillie
Thanks for the tip got a lot done today more to follow also loaded the 20k axle apart because is so heavy with the discs
