m915a1
wreckerman893
Possum Connoisseur
15,645
2,130
Mediums were made to pull deuces and smaller.
What will you be pulling it with?
I pulled a M818 (5 ton tractor) with my 915 using a medium tow bar but only a few blocks.
I would try to find a Heavy if you are going to move it any distance or at highway speeds.
You will also need safety chains, air lines and tow lights.
The drive shafts will have to be removed too.
1,823
Mediums are rated at 39,000# IIRC. Doesn't resolve the pin and feet issue though.
emr
25
landing , new jersey
:grin:...the medium is fine for 5 ton trucks, and has been used for them for as long as they have been in service... I have to say it will also be fine for the 915...
gimpyrobb
dumpsterlandingfromorbit!
27,787
774
Cincy Ohio
Where did ya end up getting one from? I know another guy that has used the med TB to tow one home. I have the adapters if you need to borrow them.
