M923 - Air Brake Diaphragm
Glenssurplus
shelby oh
Hello Steel Soldiers!
You guys have been given me valuable information so far, and I'm learning more and more about these trucks as time goes on.
I'm hoping that you guys can come through and help me again.
It seems our M923 is persistent in being a pain in the rear. We have the Actuator repaired, and now we have a leaking Air Brake Chamber. The Emergency Side Diaphragm is old, brittle, cracked, and definitely not fit for use.
Well, We pulled the Chamber off the truck, and I'm looking at it. It's a
Rockwell X76 3276 L12 | 84tc164
My mechanic assures me that the chamber is in good working order, but I need to find a replacement diaphragm. I've gone through my Manuals that I have (thank god that I was given clearance to purchase the rest of the manuals on CD), and This truck isn't listed in the ones I have.
I've checked the Diaphragm that needs to be replaced, and it is an
Anchorlock -> Division of Royal Industries
Diaphragm The only other two markings are
16" at the top of the triangle and
G-4 in a circle on its own.
What type of Diaphragm is this? Is it a standard "type"? I thought maybe it was a type 16, but upon measuring it, a type 16 is 6" diameter, and ours is 6 1/4.
If someone could help me track down a way to figure this out, I would greatly appreciate it.
bsteinborn
Keller, TX
Glenssurplus,
did you fix the rear actuator? Did you use a repair kit or find everything at NAPA? Just curious before I take mine apart. Thanks.
South
Cookeville/TN
I am having brake trouble also my m923. When the truck builds air pressure the breaks will release but after applying brakes the brakes will start to hang a lil and after hitting the brakes a few time they are stuck. Have already replaces all diaphragms and inverter and also jacked both axles up to see what wheel was hanging and all four on rear are hanging. Does anyone have any ideas?
MtnSnow
14
NSL, UT
Check the air vent on the passenger side front gladhand to make sure it is not plugged also make sure that if it has a shutoff valve in place that it is OPEN so it can vent properly
