Race1030
- 0
- 0
- Cincinnati Ohio
What type of chargers are you guys using on your 923 new to this whole thing
Can I be a dweeb and ask why you guys need a charger at all? I'm down to only 2 batteries, and as long as they are less than 5 years old, she will crank up un-assisted even on a snowy January morning. There is no draw on the batteries when the truck is off. A truck with 4 batteries should be able to sit for a very long time, and crank right up. I know I am not answering the question, but....
I make a portable one powered by a 4hp Honda commercial engine that spits out 50 amps @ 28v if you are dead and want it alive quick, in the middle of nowhere or no other 24v jump sources present.
I use the maintenance chargers more for the maintenance side of the process, as opposed to the charging side. They really do extend battery life. The desulfation process is the main reason for me.Can I be a dweeb and ask why you guys need a charger at all? I'm down to only 2 batteries, and as long as they are less than 5 years old, she will crank up un-assisted even on a snowy January morning. There is no draw on the batteries when the truck is off. A truck with 4 batteries should be able to sit for a very long time, and crank right up. I know I am not answering the question, but....
Hey discoball your alts are great but the man asked about chargers. Let's see if you can stay on target here. I personally would say that if you are going to be keeping the truck inside get a good desulfating maintenance charger, if you're keeping the truck outside I would run the solar charger shown earlier Not the small solargizer but larger one made by the same companyYou guys just need better alternators.![]()
Why do you have 4?Solar - Pulsetech. 4 of em. Of course, the replies that follow will undoubtedly scold you for not using the search function. But WELCOME nonetheless.
Why do you have 4?
Sent from my SM-G900V using Tapatalk
