M923 Smoke
HMMWV Nut
Forrest , Illinois
Is there anyway I can lessen the smoke, or blow by in on my M923? Is there a fuel additive or something out there?
I have added Lucas heavy duty oil stabilizer when i changed oil and added Howes diesel treat additive. There are many good products on the market but i have used these in the past and they have solved the issues you are experiencing.
Ue413
Springfield, Missouri
Is your 923 an 8.3? I've got constant smoking on an 8.3, but I believe good compression as it fires up immediately, but believe it has suffered from sitting and / or ether use.
Suprman
654
Stratford/Connecticut
The nhc250 motors injectors can be adjusted but you need someone old school to do it. I used to have one that fogged mosquitos still it was decently warmed up and it still smoked a bit. Depending on the color of the smoke you could be burning oil also.
JohnnyBM931A2
Crystal Lake, Illinois
Yeah, mine I think has blow by/smoking from sitting. I will try replacing the oil, and see if that helps. And yes mine is an 8.3 I am pretty sure.
Pretty easy to tell if you have an 8.3 instead of a 250.. The 8.3 is smaller, and it has a turbo on the passengers side of the engine :)
Also, if your truck has the tire inflation system, or 4 shackles on the front bumper, you know it's an A2 with the 8.3 engine.
