sd39u
- 0
- 6
- Shawnee KS
Went down to the shed to do some minor work on my M923, replaced the oil pressure sensor on the motor and the oil pressure gauge on the dash and put a new mirror on the truck. Easy enough right?
Before I started the motor, I did my usual checks of the oil and coolant levels. Noticed that my burp tank was not as full as the last time...hmmm. Checked the oil...black as could be...hmmm. Fired up the motor for the first time in 30 days and had lots of smoke so I wasn't initially concerned as we've had a lot of rain and there was probably a lot of water sitting in the muffler. I let the truck idle for about 5-6 minutes to build air while I did some other chores.
Came back to the truck, exhaust has a faint grey color to it. I figured I'd take it down the road 2-3 miles and come back to make sure everything is all OK. I get back to the shed and notice that the truck still has that faint grayish exhaust. I shut the truck down, wait about 15 minutes to let it cool. Checked the burp tank...just a hiss of steam...tank is empty...crap. Check the oil...it's all milky white...double crap. Checked the oil fill...milky gunk everywhere...triple crap.
I'm probably going to have the truck towed to the same shop that did my engine swap about 45 days ago. I'm not going to risk seizing another motor. It's only a 8 mile drive.
So...fellow 5-ton owners:
Head gasket?
Oil Cooler gasket?
Cylinder liner?
Cracked block?
Looking for some advice/help here.
Thanks!
Head gasket?
Oil Cooler gasket?
Cylinder liner?
Cracked block?
Thanks!
