M930A2 Hydraulic Issue
Steel Soldiers is supported by:
bobert2412
Centerville, Texas
I have a 1991 M930A2. It's been fine for the year I've had it. Suddenly, the steering seems bound up, hydraulic fluid is leaking from many connections. Winch, steering assist cylinder, etc... It's like it is over pressuring for some reason.
I have changed the return filter by the main hydraulic tank, with no improvement. What could I check next? Or, does anyone know a place in Texas that could handle that type of problem? I could haul it there, no problem, if I could get it it fixed.
Thanks in advance.
-Bob
simp5782
Feo, Fuerte y Formal
1,273
Memphis, TN
Pressure relief is set at 1750 psi from the factory. The pump can handle 3000psi
Have you installed a gauge line to see what your system is putting out?
Hydraulic hoses are generally rated for 3000psi or more. Most hydraulic systems run 2500psi and they dont leak so you need to know what yours is doing
bobert2412
Centerville, Texas
I have not. Will try and get that done this weekend. Thanks for the help.
Jbulach
127
Sunman Indiana
Thanks in advance.
-Bob
This doesn’t really make sense. These are two separate systems, and was all normal for a year until now. Was the truck recently submerged? Do you frequently use the winch or dump? Is the winch leaking all the time or just when the pto’s engaged, and is it pouring out, or just leaving spots while parked. Are you running over 1800rpm with the pto engaged. The steering is a problem, just wondering if you have the typical gearbox drips from the winch. Sorry ao many questions but... you need answers.
bobert2412
Centerville, Texas
No submersion. We were using the dump almost every day. The winch was only leaking around the connections where the hoses enter. The same for the connections to the power steering hydraulic assist cylinder. No on the over 1800 rpm with pro.
Jbulach
127
Sunman Indiana
Ok, so even with the PTO engaged the winch hoses should see no real pressure, unless you move the winch control levers. Also short of the hose connections being loose or a hose blown at the crimp these are fairly reliable connections. Are you certain the steering ram hoses or lines on the inside of the bulkhead fittings that pass through the frame rail are not leaking and spraying a fine stream onto the winch hoses? This may take a soldier B to turn the steering wheel with the truck running while your under the truck with eye protection and a good light to verify.
silverstate55
Big Dummy
67
Cedar City, UT
Are all the hoses old enough to start dry-rotting/cracking and causing the leaks? If you live in a dry area and have never changed any of the hoses, now might be the time...
With no pics and no further description to go on, just trying to eliminate the (potentially) obvious....
bobert2412
Centerville, Texas
I appreciate all the help. Y'all are the best in trying to help someone who is lost on a problem. I've found a fairly "local" guy who had the right MOS, and is willing to take a look. Thanks again.
