bblanchard1118
Should I even worry about trailer brakes for towing around 15k?
Are you using it commercially?Oh and do these trucks need dot numbers? And are they considered commercial vehicles?
Ive did it for 60k miles in 10months. You need to add a large transmission cooler and do away with the heat exchanger especially in the summer. Heat killed the 2 allisons i went thru. The air to air i used dropped the trans temp from 230 to 160 grossing at 55/60k.So what would you say the long term reliability would be towing under 20k mostly on road 400 miles a week
Mine is part of an aluminum radiator i modified in. Silverstate55 sells em. Its well worth the 350 and takes about 5hrs to modWhat size cooler did you use? And if you have any part numbers and info on what it took to do it, would be much appreciated
Member 155mm has an ad in the classifieds for a big trans Cooler for 50. It will help.What size cooler did you use? And if you have any part numbers and info on what it took to do it, would be much appreciated
The truck comes with a heat exchanger. Major difference from an air cooler. With a heat exchanger the trans fluid is cooled by the engine coolant. The coolest your trans temp will be is the temperature of the coolant. This is fine for short heavy hauls and most other times.So the truck doesn't come with a cooler?
