74M35A2
- 341
- 83
- Livonia, MI
Just bought a new replacement ABS ECU from SUPRMAN after over-volting mine from shutting off both dash switches at the same time. I don't think a proper design should be able to self-destruct, but whatever.
Thought I would throw up a few pics of the new module, prior to install. The module is sealed, with a Gortex vent (passes air but not water). It also has a grounding strap which connects through a mounting bolt.
If you are looking for your ABS module, it looks something like this, and has a pneumatic valve on it, located above the intermediate axle, I think. I honestly have not went under to replace it yet. I want to resolve the over-volt issue first by changing the alternator, or applying in line suppression to the module, before I install this new unit. Old module was blowing 15A fuse as soon as battery switch was flipped on. ABS light on solid. Was working perfectly before this event.
