M998 at the truck pull
Suprman
654
Stratford/Connecticut
Weighed in at 5500lbs. Should have distributed some extra weight in the floor pans first. The lowest diesel class was 7000lbs so I was at a big disadvantage to begin with. There is 12000lbs of concrete on the sled. I got it a few inches. I think if I had an extra 1000lbs of weight evenly distributed on the truck I would have done better.
FullSizeRender.jpghttps://youtu.be/l-tZzPq3jmI
bachman502
61
Chesapeake, VA
Soon you will lectured in this post by guys who say they wouldn't do that with their m998 and how you abused it. Lol
Suprman
654
Stock truck. Only thing I changed were some lights. 6.5 with 3spd trans. I did 18 psi in the front 20 rear. I should have gone lower. Low range 1st gear. I tried giving a bit of brake it didn't help. 12k was just too much weight for a 5500lb truck to pull.
Suprman
654
I live down the street. I swapped the humvee for the m1078. They don't have enough weight to stop that. There's a vid in the lmtv forum of me pulling 23k+ of concrete on the sled. I have some heavy straps so I suggested a tug o war. They were working up to doing a few trucks against the lmtv but after a few rounds some of the fair officials said to stop.
