Map Compartment Door Gasket
steelandcanvas
87
Southwestern Idaho
Anyone have a substitute product for the Deuce Map Compartment Door Gasket? The NSN is 5330-00-693-0611, P/N 7373339. I know there are alot of adhesive-backed sealing products out there, I just wanted to know if anyone had replaced the gasket with something that worked real well.
maahes
Lansing/Jackson, MI
I used the adhesive backed foam weather stripping available at most hardware stores. I cant remember the size, but the width fit in the channel and it was about 1/4 inch taller than the lip on the door. One piece all they way around the door seems pretty watertight. It is probably not submersion proof but it keeps the water out when I spray out the cab with the power washer.
1,140
I'd like to buy a pair of the correct ones for a couple of my trucks if anyone finds a source for this.
