marker lights going out. Keep blowing fuse
84cucv1ton
New Jersey
I was messing around the fuel pump in the tank. Trying to get it to work. Since then the marker lights will not work. I have headlights, brake lights and turn signals. Did everything I could think of. Any ideas? Thanks
Warthog
248
OKC, OK
There is a fuel pump in the tank? New one to me....:-D
Sounds like a ground wire issue.
n1bnc
Somersworth, NH
Check the cable light that goes down the left frame rail for damage. If it is plugged in okay upfront then look at the harness from each tail light heading to the joint in the middle. I managed to melt mine many many years ago from an ill exhaust repair.
84cucv1ton
New Jersey
thanks all the grounds seem good. has a rack body on the back so the wiring is different. just blew another fuse.. not sure what im missing cant find any bare wires..
