swhpaz
- 0
- 0
- Bullhead City, Az
Developed a massive oil leak today while driving my duece around town. Started by losing oil pressure high and low. The gauge showed I had oil pressure, but the upper and lower limits kept getting lower and lower even though the pump was still making pressure. I could smell oil in the air, so I stopped and found I was losing a lot of out out of the front of the motor, and found the oil wasn't even showing on the dip stick when I checked it.
I'll need to pressure wash the front of the motor to see where its leaking from, but can anyone suggest where, or what it maybe? The leak is really low on the motor in the very front, the front of the oil pan is really wet. Pully's and belts are dry, but its thrown oil on the engine side of the generator. I added oil to it while it was not running and it instantly started dripping off the front of the oil pan up by the gasket seal. I couldn't tell do to old oil being thrown around if that was the actual leak though...
Its a White Multi fuel engine with less than 13,000 on the odometer, not that it means anything... Temps and performance stayed good. But it did get pretty close to pumping all the oil out.
Anyone with ideas???
Thanks!!!
Chris....
Thanks!!!
Chris....
