master cylinder vent / reservior
Patgonia53
Buffalo, NY
my M35a2 has a master cylinder with vent line going to the axle tubes... can I discinnect this and attach the vent line 90 degree connector to a brake fluid reservior in the engine compartment?? Do you REALLY need the vent line.... Some master cylinders come without a hookup for vent lines !!!
turbovr6jetta
Bellingham Wa
Well I'm pretty new to MVing but on a master cylinder a vent is absolutely required. But if you hook up a remote reservoir there should be a vent on the cap. But make sure you plug the old vent line. Just in case you ever decide to ford a river. You don't want to fill your vent system with water. But like I say it is just how things are in my mind and maybe the logical way doesn't work in an MV. Wouldn't be the first thing
Flyingvan911
158
Kansas City, MO
Search the deuce forum. There are threads on installing a remote reservoir. The OEM set up is: the fuel tank vents into the slobber tube and the master cylinder vents into the vent line between the fuel tank and slobber tube. Most people change this. It is on my list. I would like to be absolutely sure the diesel couldn't reach the master cylinder no matter how improbable.
The MC is vented into the same line as the vent lines for the axle? That's odd.
turbovr6jetta
Bellingham Wa
I don't know a whole lot but if the axles are tied in its probably part of the fording package. Even if that isn't the way these trucks were setup from the military someone could of done it that way to do some fording.
