First I would like to thank everyone in advance for any help they can give me, I have never posted here before. I have an mep 002a that I acquired about 7 years ago with 12 hours on it from a tier 2 reset. I would start it every month and run my dryer off it to exercise it. I went out a few weeks a go and it was a crank no start. I check some basic things over and read some other threads here and found out about the broken plastic ball socket. mine was cracked so I replaced it, still no start. There is no white smoke out the exhaust when cranking so I am assuming it is a fuel problem. The plunger on the ip appears to be moving. It appears I am getting fuel from the ip to the injectors because when I remove the lines at the injectors and crank the engine fuel squirts out.  I had a diesel tech from my job come by this weekend to help me and he is stumped. The first question I have is about the fuel return lines from the injectors. Is there supposed to be fuel going to those lines when the switch is in prime?   When we crack the return lines and put the switch in prime there is fuel going tot he return lines. I have fuel returning to the tank when I am cranking the engine.  Thank you again for any help.
