Mep-004 in maryland
hawaiiflyer
Leonardtown MD
After a year of sitting in the yard I filled up the ole girl and turned her over. Need to replace some MIA transfer pumps, fix a small oil leak at the filer assembly and get a new lower radiator hose, but she started and ran great. Now time to clean her up a little and start tinkering with the power section.
hawaiiflyer
Leonardtown MD
She runs
I sure did. Had to remove the float switch from the day tank and fill it up directly. Gave me about a 5 minute run time. Once I get the new radiator hose and some electric transfer pumps I'll get her all warmed up and start testing out the genny.
hawaiiflyer
Leonardtown MD
No, I actually picked it up over in Chambersburg PA. I bought it through GL last year before I departed for Afghanistan. I got back this spring and have been wanting to get it started for a while. I am going to find a single 24v fuel pump and add a return line from the day tank to the main fuel cell. When you want to start it, just flip on the fuel pump, the day tank will stay full and any excess fuel is returned to the main fuel cell. I'll probably wire it through the float switch so that if it does run low on fuel the pump wont dry run.
You don't by chance have a 2 1/2 ton truck parked in your driveway do you?
PeterD
Jaffrey, NH
For a lower radiator hose, you can use a pair of 90 degree universal hoses of the correct ID, trimming to length, and a short nipple to join them together. I was never able to find the original hose, so that's what I did, worked very well. BTW, I did use two hose clamps on each hose going into that nipple (total of four.)
