MEP-531A Owners------- What do you guys use this Gen Set for in the Civilian World?
Tinstar
2,250
Edmond, Oklahoma
I picked up a 2006 MEP-531A yesterday with 27 hours on it and it is in almost new condition.
(The fuel lines need replaced)
Price too good to pass up.
What is this generator used for outside the Military?
I know what its "designed" for and what the military usually did with it.
What are you guys doing with it?
Is it worth keeping?
IMG_4823.jpegIMG_4824.jpegIMG_4825.jpegIMG_4826.jpegIMG_4827.jpegIMG_4828.jpegIMG_4829.jpegIMG_4830.jpegIMG_4831.jpegIMG_4832.jpegIMG_4833.jpeg
FarmingSmallKubota
1,348
Wapakoneta, Ohio
I keep One unit in the back of my LMTV for any power needs or if i need to charge batteries. As i fix these units i use them around the property to run 1500 watt space heaters while working on equipment outside, or charging batteries, or using heat gun or portaband saw. I have sold many units and they were going to use them for back up power in a power outage specifically one customer has a grandson that needs medical equipment to run, another customer is powering his construction trailer. many uses they just need a small trailer, strong back or a place where they can be mounted and remain
Tinstar
2,250
Edmond, Oklahoma
Ok
Thanks for the comments
Agree about the weight of the unit.
Just set the generator in the back of my cargo trailer and was quickly remined of my age.
I did read a few old threads about the tricks, like using a zip tie to tie down the fuel line in a way to make any bubbles go up, to be easier to bleed out.
I'll find out if it even runs and makes power later this week.
The heat/humidity lately has been oppressive.
2Pbfeet
1,366
Mt. Hamilton, CA
Ok
Congratulations on the buy. It looks to be in nice shape.
Judging by the residue in the fuel filter, you might want to clean the fuel tank, and then fill the new filter with a dose of SeaFoam.
Yes, priming is key with this engine, the high pressure side especially. In general though, I think it is rock solid.
All the best,
2Pbfeet
Tinstar
2,250
Edmond, Oklahoma
This morning I removed and cleaned out fuel tank.
Installed new fuel tank grommets and Tygon fuel line.
Fuel return line is fine and left that alone. Looks like it was recently replaced.
The fuel filter bowl still had some fuel sitting in it and it had caused the bottom portion of the bowl to become hazy and stained looking.
Used SuperClean cleaner and let it soak for a few minutes in the bottom of bowl.
Worked like a champ and can't even tell where the haze mark was.
Fuel filter was in new condition so will leave that in place.
Oil screen is clean and still need to add oil.
Will add oil and fuel tomorrow and see if it fires.
Still debating on what to do with this.
Waiting on parts for the 803A
New Optima battery's and other items are due to arrive today.
FarmingSmallKubota
1,348
Wapakoneta, Ohio
Do yourself a favor when you go to prime the unit and slave it from the 803. it will save your arm a lot of pulls. 17mm wrench crack the nut on the pump get fuel, then crack the line on the injector till you get fuel. Also don't forget about the decompression lever if your pulling my hand, it hurts when you do as it rips the cord out of your hand.
2Pbfeet
1,366
Mt. Hamilton, CA
If it were me, I would nudge your starter wires just a bit to free up the cooling slots on the generator head, as the other side on this model tends to be fairly occluded.
All the best,
2Pbfeet
