MEP-531A surging/hunting
djdalfaro
Salado, Texas
Hi guys, new to the forum. I just picked up this MEP 531a and I'm trying to get it running smoothly. I've gotten to the point where it stays running after starting, but it's surging an hunting and not smoothing out. I have read what I've found on the forum concerning ensuring the oil is not too full, and I drained the old oil, and have added about 600mL of fresh oil which brought up the level to the full mark with the dipstick screwed in. Any advice or suggestions to point me in the right direction would be greatly appreciated.
MEP-531a rough running
LuckeyD
401
Vilseck, Germany
Good Day: Open TM 9-6115-673-13&P to page 0013-1 and 2. Follow the steps. this will either resolve the issue or narrow it down to a couple possibilities. It is usually a fuel issue, or something related to it. Let us know what you find! Cool!
djdalfaro
Salado, Texas
Thank you. I've got new filters and fuel line coming in so I will replace those, flush the fuel, and start with the troubleshooting list.
djdalfaro
Salado, Texas
do yourself a favor and make sure the fuel line between the filter and fuel pump is clear so that you can see air in the line and bleed accordingly.
Thank you. Yes, I had seen the recommendation and new Tygon line should arrive tomorrow along with new fuel and air filters. One thing I know is contributing to my issue which will get fixed is the port elbow for the fuel pump supply is missing an o-ring, and so I know I'm getting air in the fuel system at that point. I noticed some sputtering at that point and when I hold the elbow down the running characteristics do change. I'll replace it when I do the rest of the fuel system in the next couple days.
2Pbfeet
1,518
Mt. Hamilton, CA
Good catch. These engines are quiet intolerant of air in the fuel.
All the best, 2PbFeet
djdalfaro
Salado, Texas
Ok guys, I've got an update. I went ahead and purchased a new Yanmar injection pump as my existing pump suction elbow had failed and was allowing air into the fuel at that point. I'll probably send it off to have it repaired so I can keep a spare on hand. This appears to have solved the issue of allowing air into the fuel line, and the hunting/surging issue...
However, I still seem to be running at higher RPMs and I'm getting weird readings from my multimeter (hz setting attached to 120v output). My generator hz meter is still pegged when running. This leads me to believe I have an issue with the governor. According to the manual, with the switch in run, the governor lever pointer should be centered. My old pump just had "o c", my new one does have a center mark, and when the governor is in run, the pointer is WELL to the right of center. The only way I am able to get the pointer aligned to the center mark is by extending the adjustment screw on the fuel injection limitation screw well past the specified dimension. I would appreciate if someone could open their access cover and post a picture of where their pointer sits both at run and at stop. The manual just states that if the motor is over RPMs to check the internal governor for damage. I had a thought that replacing the springs on the governor might work, and I will try that with some springs I have sitting around, but if there is an internal governor issue, I will have to dig into the motor deeper.
Video below:
MEP-531A high RPM
Guyfang
27,335
Burgkunstadt, Germany
However, I still seem to be running at higher RPMs and I'm getting weird readings from my multimeter (hz setting attached to 120v output). (What are Weird readings?) My generator hz meter is still pegged when running. This leads me to believe I have an issue with the governor. (What you need to do is establish what you have for a Hertz reading on the gen set output. Then you can decide what to do. Just because the meter is pegged, doesn't mean that the output is to high. And "still seem to be running at higher RPMs" is not proof that it is. ) According to the manual, with the switch in run, the governor lever pointer should be centered. My old pump just had "o c", my new one does have a center mark, and when the governor is in run, the pointer is WELL to the right of center. The only way I am able to get the pointer aligned to the center mark is by extending the adjustment screw on the fuel injection limitation screw well past the specified dimension. I would appreciate if someone could open their access cover and post a picture of where their pointer sits both at run and at stop. The manual just states that if the motor is over RPMs to check the internal governor for damage. I had a thought that replacing the springs on the governor might work, and I will try that with some springs I have sitting around, but if there is an internal governor issue, I will have to dig into the motor deeper.
LuckeyD
401
Vilseck, Germany
In TM 9-6115-673-13&P work Package 64 it says how to adjust and put in order the external governor and speed settings. The actual governot inside the engine that acts on the fuel rack on your injection pump is not mentioned well. Recommend trying the WP64 stuff before going inside the engine. You can see the action it does if you remove the injection pump and observe the rack and move the plunger the external speed adjustment mechanism acts on and how that is working. I have an engine book from Yanmar and the actual governor inside is not well mentioned, but it does say how to tear down and rebuild the engine if you have to go there. It will eventually be available in the TM section if it is not already there. Easy to complex OK.
djdalfaro
Salado, Texas
I was getting 300-500 hz on my multimeter. It can be seen in the video. However I also noticed at least one of my brushes was broken. I'll be replacing that as well. Thank you.
