D-Man
- 0
- 6
- Denver, Colorado
All functions were a GO on the generator. I plugged in a 1500w space heater (yes I know it is a little more than 10a) into the convenience outlet and it ran for a while until it tripped the GFCI. I reset it and everything worked fine except for the voltmeter now will not display voltage unless I turn on the battle short switch. I can turn off the switch and it will still display voltage but nothing happens until I turn that switch on. Hz display is fine at 60.
I checked the 3a 600v fuse next to the regulator and it looks fine although it may be a non-indicating fuse that may be blown. When I switch to 120/240v, it displays voltage upon starting the generator.
Any suggestions on where to begin troubleshooting would be appreciated!
Thank you.
Thank you.
