MEP-802a Oil Leak
jstew0903
12
Tampa, Florida
I have a refreshed 802a with less than 200 hours on it with an oil leak. It seems to be coming from the to on the intake/valve cover area. I ordered a valve cover gasket for it.
My question is there any other place anyone has seen an oil leak from in the upper portion of these generators? It’s pouring out at a pretty good rate. In the photo I took while it was running you can see the oil pooling up while vibrating. (You know how these two cylinder motors are)
Thank you
Light in the Dark
6,758
MA
Are you certain its not diesel fuel? I would suspect that you have seeping/leaking fuel return lines since its up top. Certainly a valve cover could leak.. but I've yet to experience it. I have experienced every conceivable leak from the return line (and the Ts they tie to) up top though.
jstew0903
12
Tampa, Florida
Yes I’m positive it’s oil. After running about eight hours it will be a quart plus low. I touch it and it’s definitely motor oil.
20,741
Smell? Like Diesel?
Looking for a potential problem - before it goes bad...
jstew0903
12
Tampa, Florida
Smell? Like Diesel?
it’s definitely an oil leak. Oil does not run uphill. Outside of the valve cover is there any place on the top of the engine near the intake and valve cover that oil would leak from? Any sensors tied in to the oil path? I ordered a new valve cover gasket to start but I don’t want to tear that down to find something else there.
Appreciate your insight
Ray70
7,092
West greenwich/RI
Nothing up there besides the valve covers and the silicone O-rings around the shoulders of the "nuts" that hold them on..... that would leak oil.
On the 2 valve cover nuts with fuel line clamps on them, make sure they put the O-ring into the recess in the valve cover, then the fuel line clamp over the O-ring, then the nut on top. The O-ring does not go on the shoulder of those 2 particular nuts.
jstew0903
12
Tampa, Florida
Thank you.
I guess I need to order the O Rings. Anyone have part numbers or a source or link?
Ray70
7,092
West greenwich/RI
Looking at the engine TM it says PN 201-81200 which is also part of gasket kit PN 186-3210 or 186-6212.... which is the full engine gasket kit.
Or here is a replacement:
But not the same OEM orange silicone.
To be honest, you could easily take an old one out, measure it and get them for $.05 each at a place like www.throringstore.com
jstew0903
12
Tampa, Florida
Thank you very much
2Pbfeet
1,471
Mt. Hamilton, CA
Great idea. Typo? https://www.theoringstore.com/?
I also get o-rings from McMaster.com
All the best,
2PbFeet
