Mep-803a coolant water coming out of drain hose while running
chilbun28
116
33
Deep South
Apparently I'm loosing coolant from the drain hose while the generator is running. I'm pretty sure the low point radiator pet cock is not leaking by. What would cause coolant to flow out of the hose while running? Also, the over flow tank, the coolant level sometimes rises and falls while the motor is running, is this normal? I have filled the radiator, ran the engine, and flushed out the water 5 times due to the coolant looking really dirty. While flushing the coolant is when I found the issues.
Light in the Dark
6,600
MA
If it didnt shut down from coolant overtemp or was smoking and making noise, you should be fine. The drain valves on these don't drain out all that quickly. Just make sure you top the system off till it wont take any more, then run for a bit, and top off again. The blocks can sometimes be air bound on these, not the best laid out system. You should be fine though.
