MEP 805b generator crank no start-
MrShawn305
97
El Paso, TX
Proved out actuator on injector pump is operating. Fuel is getting to pump, zero pressure or fuel coming out of injector lines or from the return line. Lift pump has good flow.
At this point suspecting injector pump is plugged up or failed, any ideas as to where to get a new pump or a rebuilt pump?
I haven't been able to find one cheaper than about 2k. The local John Deere dealer can get it, I think there was an outfit online that was able to get it too. Just need the engine serial number, the part number on the pump helps alot too
Boozer
Arizona
Okay thank you - dang it! This machine is getting very frustrating.
Julio Wu
TAIWAN
You can try to change the CIM. Because the low oil pressure is displayed, it will appear as soon as the screen is turned on. If the I/O does not reply to the screen, the screen fault signal will not be cleared. This way the machine cannot be turned on.
Boozer
Arizona
Does anyone know of a used injection pump. I have had this unit two years and still haven’t found an injection pump for it.
