I have a MEP-831a that I bought with 41 hours on it. It currently has 49 hours. We were using the generator and it was working fine with no issues. The next day we went to restart the unit and now we have a problem. The unit restarts and comes up to speed normally. The voltage gauge will rise to a normal level and then a second or so later it will drop all load and the overload light comes on. Nothing is plugged into the unit so if there is a short it must be internal. I'm not able to determine if it's a low voltage or high voltage short. Nothing appears amiss inside and all connections are tight with the silicone sealant. When the overload light comes on it seems as if the automatic governor is losing power because there is no response when the red button is pushed. If I try to manually over ride the automatic governor the unit will shut it's self down. Any help would be appreciated!
