MEP-8xx Filters Information
Daybreak
2 Star Admiral
1,522
778
Va
MEP-803A + MEP-802A Filters Information
MEP-802A ONAN DN2M 2-cylinder engine (Lister-Petter LPW2)
MEP-803A ONAN DN4M 4-cylinder engine (Lister-Petter LPW4)
MEP-8xx Filters List
Oil Filter Spin-On (FILTER ELEMENT,FLUID NSN#2940-01-154-5127 )
Prefer WIX 51374, Napa 1374, works also(WIX 51348, NAPA 1348 ), FLEETGUARD LF3335, BALDWIN BT223, DONALDSON P550335, FRAM PH3614, PUROLATOR L10241, CHAMP PH2835
Fuel Filter cartridge (FILTER ELEMENT,FLUID, CARTRIDGE NSN#2910-00-099-5467 )
WIX 33348, NAPA 3348, FLEETGUARD FF4012, BALDWIN PF-847, DONALDSON P13, FRAM C11941, PUROLATOR F53121
Fuel Filter, Spin-On Fuel/Water Separator Filter (FILTER,FLUID NSN# 2910-01-376-5666 )
True Military filter with drain connector 85285-F
Alternate replacements, with bottom drain, but, factory drain with hose does NOT connect WIX 33472, NAPA 3472, FLEETGUARD FS1251, BALDWIN BF1226, DONALDSON P550248, FRAM P8043, PUROLATOR F64424
Air Filter (FILTER ELEMENT,INTAKE AIR CLEANER NSN#2940-00-934-7989 )
WIX 42276, NAPA 2276, FLEETGUARD AF435KM, BALDWIN PA1960FN, DONALDSON P181050, FRAM CAK256
There are many other filters out there. The best is a quality filter for a good price.
Oil Type
15W-40 Heavy Duty Diesel Engine Oil
Same thing here, whatever oil you want to use.
Coolant
Heavy Duty Diesel Type
Chrispyny
13
NY
This needs to be a STICKY for sure. Thanks man. Now that i have one coming, it's good to know. I love this place.
Rebel635
Toronto, on
FYI napa is having a 60% off filter sale till end of October and ALL mep-802a filters fall under the sale and at %60 percent. Just bought 5 filters of each but air (three of those) for what three airfilters would have cost me locally (i live in Canada). I dont know if this is a national sale or just regional, but i bought them in greater Los Angeles area.
Daybreak
2 Star Admiral
1,522
778
Va
Howdy,
After many different filters out there, I lean towards the Napa/Wix filters. They are well made, have many models covered, and are easy to find.
Daybreak
2 Star Admiral
1,522
778
Va
Howdy,
Has anyone come across a spin-on fuel filter which has the correct water drain fitting on the bottom?
All the others work for the job. I was just wondering why none of the aftermarket ones have the correct size fitting.
Daybreak
2 Star Admiral
1,522
778
Va
Howdy,
The true correct spin-on fuel/water separator model 85285-F has the water drain attached at the bottom. Most of the aftermarket civilian fuel/water filters do not have the same size fitting at the bottom. So, I do not use the fitting or hose. I do not drain off any water. I use the NAPA #3472 without any issues.
Haoleb
11
Raymond, Maine
I have what may be a stupid question about the WIX 33472 Fuel/Water Seperator...
It comes with a round gasket which I assume goes over the threaded nipple on the fuel filter base. Are folks using this gasket with this filter and the stock filter base? When i set the gasket onto the filter it seems like it sits lower than the outer gasket. Like if I screw on the filter the outer seal will make contact and seal before the inner one ever would since the entire base is a flat surface.
