Mfg. ?
Oasis-3
Columbia, PA
How can I find out who is the Mfg. of the trailer I just picked up at GL.
It was listed as MDL M101-A1 the data plate showes it's a 1962 but the MFG. is blank. I have the vin.# if that helps.
Thanks
319
Lieutenant
3,347
58
Michigan
Need to find someone with an intact complete data plate on their 1962 M101A1. It should be the same manufacturer.
NDT
7,456
Camp Wood/LC, TX
Johnson Furnace? Post all the numbers you have and let us sleuths get to work. Should be 5 lug Budd wheel with no surge brakes to be a 1962.
Oasis-3
Columbia, PA
Thanks for the replies
Year 1962
Fed # 233-898-6779
Mfr#2359
DTID W25M6N023530A4A
NSN 2330008986779
I have a 1968 Johnson Corp. and getting a SF97 was easy for that one.
If I can get the correct name for this 1962 I will stamp it on to the data plate then I can get a good title for this one.
Thanks Again
Oasis-3
Columbia, PA
Cage Code, = 19207
Ok good Idea
NSN:2330008986779 [FONT=Verdana, Arial, Helvetica, sans-serif]Item Name:[/FONT]TRAILER,CARGO Query Type: PUBLICDate of query:12/24/2010 3:09:32 AM
M101A1 19207A515AZ3D8736397 19207A511AZ3D13212E3552 97403A521AZMILT10579 81349M41XTG3D
NAMEITEM NAMETRAILER,CARGO AAFZBODY MATERIALSTEELABHPOVERALL LENGTH147.375 INCHES NOMINALABMKOVERALL WIDTH73.500 INCHES NOMINALADJTINSIDE WIDTH66.000 INCHES NOMINALADJUINSIDE LENGTH96.000 INCHES NOMINALAFMQINSIDE HEIGHT18.000 INCHES NOMINALAJGEBODY TYPEBOX W/LATTICE SIDE EXTENSIONSALYPFLOOR LEVEL DESIGNFLATAPGFDESIGN TYPEWHEELEDATYXCAPACITY RATING0.750 TONSAWHABED TYPEFIXEDAYFNSUPPORT TYPEADJUSTABLE LEGAZBTWHEEL ARRANGEMENT STYLE2 SEMI REAR, SINGLEBPGNPARKING BRAKESINCLUDEDBPQWSUSPENSION TYPETHROUGH SHAFT AXLEBRRZTARPAULININCLUDEDBRSBTOP BOWSINCLUDEDBRSDTAILGATEINCLUDEDBXJLRETRACTABLE SUPPORT FEATUREINCLUDEDCCRWDRAWBAR TYPERIGID A-FRAMECGNWLOADING RAMPNOT INCLUDEDCGNXDISTANCE FROM BODY FRONT TO DRAWBAR COUPLER CENTER41.750 INCHES NOMINALCGPGDRAWBAR CHARACTERISTICFIXEDCGPHDRAWBAR COUPLER TYPELUNETTECGPKTOWING PINTLE HOOKNOT INCLUDEDCGPNBODY FRONT SHAPESTRAIGHTCGPPPLATFORM LOADING HEIGHT ADJUSTABILITYNONADJUSTABLEZZZTNONDEFINITIVE SPEC/STD DATAM101A1​
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]http://www.dlis.dla.mil/webflis/pub/pub_search.aspx[/FONT][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
[/FONT]
still looking for a name
Search by
CAGE Code: 19207
Company Name: U S ARMY TANK AUTOMOTIVE COMMAND CAGE Code: 19207 DUNS Number: JCP Cert. Number: ZIP Code: 48397 State: MI Phone:
Name:U S ARMY TANK AUTOMOTIVE COMMAND
AMSTA-IM-MM CAGE Code:19207 Status:A - Active RecordParent CAGE:Address:11 MILE RD P.O. Box:City:WARREN ZIP:48397 CAO-ADP:S2305A - HQ0337State:MI County:MACOMB Voice Phone Number:Fax Phone Number:Date CAGE Code Established:11/27/1974Last Updated:8/31/2004
[FONT=Arial,Helvetica,Univers,Zurich BT,sans-serif][SIZE=-2]Last Updated: Monday, November 17, 2008[/SIZE][/FONT]​
Company Name = US Army Tank Automotive Command
Ouch looks like a dead end aua
Good Try 4X4
jaxsof
15
Dundalk, MD
I have found a few, and all 1962s I have found were made by JETA MFG. I dont think they are related to the company with the same name in Neenah, WI
Hope it helps
Scarecrow1
Florence , S.C.
I agree with NDT your # s are close to mine and its made by Johnson corp Bellevue ,Ohio the national stock # is 2330-00-898-6779 your Fed # 233-898-6779
mine is a 1968
Wolf.Dose
10
Boehl-Iggelheim, Germany
But it might be a Case Master Body Inc. or GAr Wood Industries as well. There are many makers for these trailers.
All have 4 didget serial numbers in the 1960's.
All M101A1 have the FSN 2330-898-6779.
Refer to TM 9-2330-202-14P, August 1962.
Wolf
