Military Tail Lights
Naila
California
Would like to install military tail lights and housing to my 2010 jeep. Anybody have an idea to complete mission? Need to convert to 12v
1,814
If you purchase LEDs, they are mostly omnivolt. You can either bolt them right to the sheetmetal or sink them in hmmwv light buckets.
KsM715
142
St George Ks
Did it to my Jeep a few years ago. It's easy. Change the bulbs with the ones that are listed in the link above and if I can find it there is a chart that will tell you which wire on the military light will correspond with the tail light, turn/brake and so on
my Jeep, http://www.steelsoldiers.com/showthread.php?55356-Let-there-be-light-(taillights)&highlight=
Found it. The very first post in this thread should tell you everything you need to know. http://www.steelsoldiers.com/showth...ler-wiring-info&highlight=12volt+bulb+numbers
NEIOWA
115
NE IOWA
M916A3 had bad tail light set. Or seems so. Looks like light switch is bad though.
M916A3 has LED surface mount (no bucket) 6220015148507 LIGHT SET,STOP LIGH Anyone know if this is same part number installed in a bucket in other installations?
jaxpaxct
Dillsburg, PA
I did this to my 1995 Jeep. I bought a set off ebay. However I modified the interior of the military light to accept the guts of the original tail light. It works great, however it sticks out about 5-6 inches. Thinking about cutting the light body in half to bring it closer to the jeep.
papakb
1,186
San Jose, Ca
Naila, The Korean era round taillights will drop right in in place of the Jeep taillights but your going to have to do some cutting to get the later composite taillights into the body. Either way you can either just replace the 24v bulbs with 10-30 volt LEDs and your good to go. To mount the composite lamps your going to need to pick up a pair of taillight buckets from any of the newer M series trucks and fit them to the Jeep body then the lights will bolt directly into them. Remember that if you go the composite light route that both bolts need to be installed because the lamps ground through both of them.
Kurt
Ferroequinologist
Resident railroad expert
724
Liberty Hill, SC
Yes, they are the same. Just take them off the bucket. I might have a set somewhere without buckets let me look when I get home.
