Military Turn Signal units and 6 volt electrical
maddawg308
798
Appomattox, VA
I know the standard military turn signal units will run on 24/28 volts, and on 12 volts, but does anyone know if they will work on 6 volt?
cbvet
20
Northwest (Knox) Indiana
Are you talking about the turn signal switch that attaches to the steering column?
If so, then yes, it's just a switch.
If you're including the flasher unit, then I doubt if it would work on 6 volts.
Eric
CBVET
maddawg308
798
Appomattox, VA
cbvet - thanks, yes I was talking about the switch. I can use the stock flasher that the CJ3A has, just the turn signal switch is all boogered up along with the wires, and have a switch laying around.
gwalker - thanks, but I like the military sealed system better than the one in the link. Actually I had that style, myself. But I also have a switch laying around, so I don't need to buy anything else. Just wanted to know if it would work or if there were some internal components that might not like the 6 volt system.
