Mk23 First Gear
Camoguy
66
Oxford nc
2002 MK23 Does anyone know the sequence to get the truck into first gear. The manuel says to select mode then shift down to first. However the manual is showing a more modern shift panel with 2 digits. My shift panel only has a single digit. (Doesn't work for me)
My understanding is that first gear is taking the place of a low gear that would normaly be in the T-case. I can only shift down to 2nd.
Elijah95
Certified Rookie
1,240
1,214
Georgia
With my 01, you put it into drive, then tap the down button until you reach first gear “1”
Camoguy
66
Oxford nc
Well that sucks to hear. I cant go past 2nd. Is there anything that might be engaged that may keep it from shifting into first like a safety switch on a lawn mower seat?
MAdams
140
San Dimas, CA
Every once and a while mine won't let me into 1st. I press the down arrow several times but it stops at 2. The next time I drive the truck is fine going into 1. Who knows
Sent from my SM-G975U using Tapatalk
Camoguy
66
Oxford nc
Cargo load settings must be 7 tons or less. If it is set it to full load the transmission will not shift to first. Also learned you can lock all three diffs and t-case by pushing the lock button 3 times once you lower the load & terrain settings. BEAST MODE😎
🙄 Now that being said I felt like I tried that five different ways and it did not work. But I read the instructions and now it works every time.
