5tonpuller
- 24
- 18
- Thompson, Pa
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=22739&highlight=muffler
Ok I put a NAPA muffler 21470 on my truck ( as you can see in the post above )
I set it up so I could use ether the stock stack OR the muffler. It is like a 5 min. change over.
The cone is made from 1/4 wall thick steel tubbing 3/4 long with a 5/8 outside 30% angle on ether end.
Used 2 NAPA adapters 41865. 1 NAPA adapter 41657 and had it stretched at muffler shop to 3 1/2 ID. I had to cut the J pipe 5" because of the door. Took that peace with me to make sure it fits tight. Loose is no good.
Beleave it or not the muffler weight is only 3-4 Lbs. more then the stack pipe. WOW
( what do I know )
Bent one mirror bracket with a conduit bender some. The other bracket came from a 5
ton tractor. For some reason it was 2" longer then the one that was on the wrecker.
All these things got wielded on to there other parts.
One NAPA collier 35496.
Now to change all it takes it a 1/2 wrench. Mind you if you have run it for more then 20 minutes things are HOT !! So gloves or wait till it cools some before you change things.
He is some picture of the project. ( hope the servers don't dump me for the band with I used )
Now I can hear my self think.
![Laughing :lol: :lol:](https://www.steelsoldiers.com/images/smilies/icon_lol.gif)
( what do I know )
