Mounting winch on m929,hyds ?
jcappeljr
27
Delta, PA.
I am mounting a hyd winch on my m929.I removed it from a m925.I mounted it on the truck,ran the 2 lines back towards the existing hyd valve.Does any body have any pics how the military hooked them up on the m930s.I am thinking I need to tee into the line leaving the pump and add another valve to actuate the winch.I have another usmc truck with a complete hyd.system.I am not sure if there is enough oil capacity in the dump resevior to run the winch.The pump looks identical on the m929 as is the one on the winch truck.A pic would help alot.thanks.
Artisan
227
CDA Idaho
Try TM ...24P-2 Starting Pg. 942
Not sure if this is what you seek or not.
Scroll up and down from there.
