- 18,204
- 27,338
- 113
- Burgkunstadt, Germany
Will the black knob part of the linkage move freely in the long slot? Because if its tight, and will not slide in the long hole, it wrong,
Yes the knob moves freely in the slot.Will the black knob part of the linkage move freely in the long slot? Because if its tight, and will not slide in the long hole, it wrong,
The spring on the solenoid is in working order, I checked at all ready.Is the spring broken, or missing in the rubber "prophylactic" on the piston? Have you made sure the piston slides in and out of the solenoid housing smoothly?
