Mtvr tow bar connectors
10isBestmm
San Antonio, Texas
Gents,
I pulled up the motivation and took the feet off my heavy tow bar to make sure itd fit.
The tow bar has 1.5" pins and the gap is 2".
The gap I need is 1.5" rough abouts.
Can I just throw in some washers or is there a similar connector I could use instead.
Also, how bad would it be to use it as is?
simp5782
Feo, Fuerte y Formal
9,511
Mason, TN
Gents,
The mtvr feet are a different size on each end. One side is narrower than the other if you have the mtvr towbar kit.
If you are using The old school heavy bar with its 1.5in feet there will be some slop. It doesn't hurt anything cause once both feet are on and the bar is hooked to a truck it's not going to flex much. The 1.5in pins are rated at over 120k. That 7 ton isn't going to break em
