Muffler installed
rmgill
14
Decatur, Ga
OK, with an impending trip, I decided to get a muffler and get it installed for the trip to ease my ears. I purchased one of the walker mufflers that everyone seems to be using. Advance Autoparts sells them as does NAPA, however out the door, I was looking at $80 for one vs $48 from Advance. Both were shipping it in from a warehouse in Kentucky, but advance has a daily truck NAPA was going to charge me for UPS. So, Advance Autoparts got my business.
Before and After
rmgill
14
Decatur, Ga
The muffler comes slotted on both ends so you can slip it on over the 3.5" pipes. However, I was short a good 3.5" clamp and wanted to keep the cutting on the truck to a minimum. So I elected to weld a short portion of the cut off pipe to the top of the muffler so I could add the exhaust tip easily with out any other changes on the truck. This allows the use of the "v" profile clamp to pull off the tip if I need to reduce the height at all.
rmgill
14
Decatur, Ga
In speaking with Mark Elrod about this, he stressed that the muffler needed to be braced to prevent it swaying around, otherwise I'd get a cracked turbo or manifold. I had been initially thinking about bracing below the muffler, but decided to brace at the clamping point just above the fender with a off of the cowl bracket and clamp a strap around the muffler itself to the cowl bracket as well. This would support the muffler and keep it steady.
I clearly need to paint the truck as the mix of paints is just too obvious. :oops:
mcinfantry
denham springs/ la
i keep burning all the paint off of mine in the center of the muffler. its weird because the usmc green burns off, to leave the red oxide primer. that doesnt burn off. i mean it burns off in about 2 or 3 days. of course, it IS turned up
wallew
Get some paint made for either headers or BBQ grills. Both should handle AT LEAST 1200 - 1500 degrees.
The BBQ paint only has a few colors while the header paint has a couple of dozen. I'm going to paint mine flat black, as that paint is available everywhere. And it looks like it belongs.
Ryan, how about an Advance part number? And what did you use to raise your AIR intake?? I really like IT a lot also. I noticed you painted it black. That's what I'm going to do to my muffler.
Hope that helps. jim
rmgill
14
Decatur, Ga
Actually, Advance can look up the same walker muffler part number. Seems to be VERY universal. The Air intake is just an exhaust elbow with a split in one end, fits the system perfectly. Its actually an off color of OD green. Today, I shot it with a touch of 383 green. Now I really want to repaint the entire truck. I'll probably start hitting parts of it with rattle can primer and green and do it in stages.
rmgill
14
Decatur, Ga
Ok, this muffler s much quieter. I can hear other sounds from the engine compartment. I figure some insulation inside the hood and side panels will make this a much more quiet vehicle.
