Multi Adapter Box
andyindy
Rising Sun Indiana
This is what i came up with to pull civilan trailers,still have to change the bulbs but this box adapts to all my trailers. Next step is to put a reducer in each leg if they make such a thing. Brakes on trailer are no problem because they are all air brakes.:-D Andy...............
shootiniron
13
Escalante,Utah
I'm interested in how this will work for you as I'm looking for an easy way to pull my four wheeler trailer to the desert with functioning 12 volt lights.
joeypushjr1
tallmadge ohio
i would like to see how you mount the thing do you put it to the truck somhow or on the toung of the trailor.. could you post some pics.... did you use a terminal block inside the box or stay-cons ??
andyindy
Rising Sun Indiana
Hey joeypushjr, just used enclosed termnial box, made the "pigtails" going to the plugs long enough to lay the block out of the box and connect everything up, then put back in box. I used 2 machine screws w/ wing nuts to secure block to side of box. Also used# 10 ring stakeons on wire ends. For now just laying box in trailer tongue, works OK. This is my week to work(7/12's) and will get some pics up next week . :-D Andy............
