multifuel engine fan measurements
JasonS
202
Eastern SD
I am looking for a fan to fit a deuce gas engine with four bolt holes. The multifuel fan looks like it might work. Can someone measure the hub pilot diameter, bolt circle diameter, and overall fan diameter? Thanks.
JasonS
202
Eastern SD
I am replacing the original REO OA331 engine with a later model REO OH200 engine. The later model engine has a larger water pump and a 4-bolt pattern for the fan. The original OA331 fan fits on to the hub but requires six bolts.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
Multifuel fan is also 20"diam. but heavier, with 6 blades equally spaced, 4 bolts 5/16”, on 2 3/16" bolt circle. Center hole (pump shaft diam.) is 1 ½”.
Gerhard
